7 members (kades51, Forty9, Peggy M, greenie-reddy, ShopRag, Bill Hanlon, 1 invisible),
88
Mod | | | Forums66 Topics128,185 Posts1,057,281 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 6 New Guy | | New Guy Joined: Dec 2011 Posts: 6 | I am rebuilding a 1950 3100 chevy truck, and am working on the brake & clutch pedal. I bought the new bushing for the shaft pivot arm from Jim Carter, but the shaft has steps worn in it. Does any one make a replacement shaft, for this PROBLEM, can you help?
1950 3100 1/2 ton owned sense 1972
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I would put a post in parts wanted section and get a replacement there are alot of bare frames out there that have good ones on them,I had one but gave it to a father and son that were going to build a truck.
Pete | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Welcome to the stovebolt. I may be able to help. PM sent | | | | | Joined: Dec 2012 Posts: 122 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 122 | Had the same problem... took the pedal assembly completely apart, welded up the worn areas on the pins (watch your HEAT! they're hollow!), turned them down in a lathe, reinstalled with new bushings. Like new again!
Greg | | |
