1 members (qside), 72 guests, and 2 robots.
Topics128,049
Posts1,055,741
#803545 12/04/2011 11:03 PM
How do you remove the two outer L peices, that bolt through the wood as well as the sides of the bed? I removed the bolts through the wood on the hoizontal peice, and the two bolts that connect the vertical peices to the sides of the bed, but they're still stuck to the sides of the bed, are they welded on? Thanks!
1940 Chevy 1/2 ton, 12 volt, 350/350th
yes they're welded, you need to drill out the spot welds if you want to remove them
squeeze #803576 12/05/2011 12:35 AM
do you really need to remove them?Venders have a cover strip that works pretty good.You can remove rust and repair the originals,paint to seal,then cover them up
BC52 #803814 12/05/2011 8:06 PM
Anyone have any opinions on the angle strip covers? How well do they fit? Do they look good? I may leave my old ones on and get the covers, just wondering if anyone has any experiences with them.
BC52 #803836 12/05/2011 9:52 PM
Not trying to hi-jack your thread stevebolt but i'm curious about these too.
Mine aren't bad enough to warrant replacing them but they could do with a tidy up.
BC52 Do you have any more info on these?
More pix on Flickr.
I just removed mine. Not very much fun. I used a spot weld cutter bit that I bought at Harbor Freight for $5. Other vendors sell different versions at bigger prices. Basically, it cuts a circle around the spot weld. You want to be sure to only cut through the top piece. If you wedge a putty knife between the bed side and the angle strip, the pressure will cause the angle strip to "pop" up once you are through the top piece. The biggest challenge I had was finding EXACTLY where the spot weld was at! The putty knife can help you locate the spot welds too, just feel around.
After the strip is removed, you will be left with small dots of metal that you remove with an angle grinder.
See pics or go to my website and see the BODYWORK page.
http://i618.photobucket.com/albums/tt269/fastboatman29212/65%20Chevy%20C10/DSCN0857.jpg
http://i618.photobucket.com/albums/tt269/fastboatman29212/65%20Chevy%20C10/DSCN0858.jpg
http://i618.photobucket.com/albums/tt269/fastboatman29212/65%20Chevy%20C10/DSCN0861.jpg
http://i618.photobucket.com/albums/tt269/fastboatman29212/65%20Chevy%20C10/DSCN0864.jpg
Lugnutz #804383 12/07/2011 12:10 PM
I have used the covers as a temporary cosmetic-measure. They look fine - better than the rusted/pitted side strip pieces.
We removed the strips during metal clean-up because they were severely rusted. They will be replaced with "plug-welded" stainless-steel strips (maybe next summer).
I agree with Tim... Removing the angle strips from the bedsides allows for complete rust removal and fix. Otherwise the rust and remaining grit will bleed through the paint and as we know (according to Neil Young): "rust never sleeps."
All depends on how fussy you are.
1946 GMC Project
"Back-in-the-day Restore"
