2 members (cmayna, TUTS 59), 164 guests, and 0 robots.
Topics128,113
Posts1,056,612
Members48,450
hi guys i dont know what engine i have exactly so i was wandering if i can post a vid on you tube,you could guide me....first thing i want to do is rebuild/buy the carb...if the mod agrees ill post a link when i can to the vid tia
old guys and their old trucks rule!
there's a number on the block that will tell you what engine you have. Do you have a 6cyl. or v8? what year truck?
Tommy
59 apache 1/2t
261 short stepside
1951 gmc 6 cyl,,,,where is this number thnks
Leo Offline
Moderator
Moderator
There should be a number stamped on the block, just behind the base of the distributor. Likely, there will be a layer of oil crusted over it.
i will go look today and post a vid on yt because i dont hAVE a photobucket acc.thanx
Links to photos and/videos only please. No actual photos are permitted n the Bolt.
Thanks.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
hey 53moneypit I love your "new" huge shop! any more pix?
*UNDER CONSTRUCTION*
1953 Chevrolet 3100 1/2 ton-previously abandoned resto.
My Project Bolt
I hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
either it will have a 228 or 248 but until you come back with some #'s were still grasping
sorry guys it a 1959 not 51.....and yes i read the rules no pix in the forums...any way here is the link thanks
Interesting video, but not enough information. There is a machined pad right behind the distributor, with a stamped, not cast number. The first few digits of that number indicate engine size, 228, 248, 270, 302, etc. Somebody might be able to cross-reference the casting number, but the stamped number will identify the engine size for sure.
thanks jerry i will look t the number again ant tis time ill remember its stamped not cast 1953 panel said it but i was too exited to take pics that i forgot where to look
That video was plenty of information. That is a 270 gmc 6 cylinder. It appears to be the correct original engine.
What luck. Nice grille and correct engine for a 59 GMC.
58 gmc 100 with 350 sbc
I think John can tell by the 2324003 casting number in the block=55-62 270ci.
thank you for the kind words LarryW and the rest of you folks for the info.I am gathering as much info as i can since my dad in law wont let me touch it yet.
we found a zenith carb and my F.I.L said that it was original.
right now im looking for some doors since the ones we have are rusted badly on the bottom.i will buy a cover for it so rain cant get into the cab anymore...
thanks again
Seth
i found the cast number it is F 270 922 845 and i need to find a carb if anyone has one for sale can you email me please [email protected] thanks
1 Offline
On the GMC inline blocks I've been working on the serial on the deck at the distributor base always had a prefix number. If it was a 228. it stated that in the first three numbers. Even the 450 and 503 had that system.
I meant I found the stamped number exactly wher you guys said it was.thanks..
123456789101112 Is your location in Victorville ca??do you have a shop??
The prefix "F" is a factory code that indicates a block/bore spec that is "non standard" (different prefix letters mean different variances from standard). This is common and standard on many GMC 6-cylinder blocks.
There is information on this code at Rob English's oldGMCtrucks.com website. That information (taken from GMC documentation, also shown on Rob's site) states that the "F" code is a suffix. However, it looks like GMC document-writers got "prefix" and suffix" mixed up and the code is actually a prefix code/letter, as you found.
If you are interested in buying/selling parts, place an ad in the Swap Meet.
Quick update.
I found out that the 270 is not stuck,it spins freely.
I also found the correct carburetor,Im slowly buying parts.
Im still missing the starter and I think It will be ready to start it.
Im just tinkering with this truck since I have a major project going on.
In the meanwhile I found a 302 gmc and a 270 gmc with the "H" head.
I dont have a project to stick the 302 into but I know it's out there.
well Thanks I will update as I go.
