2 members (216wny, Hotrod Lincoln), 68 guests, and 2 robots.
Topics128,036
Posts1,055,458
Members48,422
#803443 12/04/2011 4:50 PM
Just converted to 12v with problems. New cap and rotor new plugs new points and condenser Before new cap I had no spark at #3. With new cap it changed to #5 no spark. Idles fine but hit the gas and it breaks up bad. Could the dist, be bad? It's original. Correct plug gap and dwell.
bgd54 #803453 12/04/2011 5:20 PM
No new plug wires? Usually a miss is wire or plug related and rarely caused by the other parts you replaced.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
bgd54 #803454 12/04/2011 5:20 PM
3B Offline
Hy bgd54, Have you checked the distributor itself, the cam and the bushings? You didn't tell us what you're working on?
3B #803499 12/04/2011 8:17 PM
Oops sorry. It's a 54 150 stock motor. I have not pulled the distributor out and physically looked at it. I was thinking since it's the stock one that maybe the 12v was to much for it. I don't really know that would do anything but worth a guess
bgd54 #803516 12/04/2011 9:38 PM
3B Offline
Hy bgd54, the distributor will have no problem with the twelve volts. I think you should check for wear in the distributor bushings. If you have access to a dwell meter hook it up and run the engine, worn parts will result in inconsistant readings on the meter, or you could remove the disributor and physically check for wear.
3B #803523 12/04/2011 10:01 PM
Ok thanks. I'll pull it apart and check it out.
bgd54 #803532 12/04/2011 10:21 PM
Riding in the Passing Lane
Check the point gap in several positions of the engine. It could be a bent dist shsft.
1972 Chevy c10 Cheyenne Super
