0 members (),
66
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 8 New Guy | | New Guy Joined: Nov 2011 Posts: 8 | Just converted to 12v with problems. New cap and rotor new plugs new points and condenser Before new cap I had no spark at #3. With new cap it changed to #5 no spark. Idles fine but hit the gas and it breaks up bad. Could the dist, be bad? It's original. Correct plug gap and dwell. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | No new plug wires? Usually a miss is wire or plug related and rarely caused by the other parts you replaced. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy bgd54, Have you checked the distributor itself, the cam and the bushings? You didn't tell us what you're working on? | | | | | Joined: Nov 2011 Posts: 8 New Guy | | New Guy Joined: Nov 2011 Posts: 8 | Oops sorry. It's a 54 150 stock motor. I have not pulled the distributor out and physically looked at it. I was thinking since it's the stock one that maybe the 12v was to much for it. I don't really know that would do anything but worth a guess | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy bgd54, the distributor will have no problem with the twelve volts. I think you should check for wear in the distributor bushings. If you have access to a dwell meter hook it up and run the engine, worn parts will result in inconsistant readings on the meter, or you could remove the disributor and physically check for wear. | | | | | Joined: Nov 2011 Posts: 8 New Guy | | New Guy Joined: Nov 2011 Posts: 8 | Ok thanks. I'll pull it apart and check it out. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Check the point gap in several positions of the engine. It could be a bent dist shsft. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
