0 members (),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | For the 1st time, my family took the truck to get our Christmas tree. It was alot of fun. The truck ran great to the tree farm and to the Dairy Queen afterwards. However, after finishing our DQ, the truck would not start. The lights came on, the dome turned on and all power seemed normal. So I didn't think it was the battery. After a jump start, it ran fine all the way home. Do you think its my battery or the alternator? Your thoughts? It will be a Christmas we won't forget. I love that old truck!
Thom Masterson
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | may be the plug at the wire fall . sometimes a little wiggle there gets it all going again. time for a little cleanup and some of that dialectic grease- a possibility ron how did I get that backwards. should have read fire wall!!!!!!!!!!
| | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | If it happens again it could also be a bad starter. Occasionally two flats opposite each other on the commutator can go bad. When this bad pair line up with the brushes, the starter won’t spin. Bumping the solenoid a few times can sometimes jiggle the starter enough for the brushes to pick up the next good pair and the starter acts perfectly normal.
I’ve also experienced similar problems caused by loose starter case bolts (the through bolts holding it together), or a loose or dirty cable connection at the starter or the battery.
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Sounds like a memorable trip. I had a similar problem once with my '70 Nova back in the early 1980's. It was corroded battery cable where it attached to the battery. Had enough juice for the lights and accessories, but not enough to crank the motor. I cleaned everything up real good and it solved the problem. Eazy Peazy Lemon Squeezy
| | | | | Joined: Mar 2009 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 51 | | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Mine was the starter, It would start fine cold but just click when hot. Went to a heavy duty starter andit now spins like a race car. | | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | Thanks guys. I had put a new starter on it this summer. Not a heavy duty one, but a new one. I think it might be the battery cables and/or terminals as well. At least that's what I'm hoping because of the cheap fix. I'll let you know.
Thom Masterson
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | If it won't engage the starter is is somthing else. No click no nothing?? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | could well be the starter solenoid overheating, a rest while you got to jumping it let it work again .... Chev starters are prone to bad behaviour when hot, especially the cheap ones  Bill | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | Normally this indicates either loose or dirty terminal connections or a dead battery, although as noted above it can also be the solenoid. If it won't engage the starter is is somthing else. No click no nothing?? | | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | I replaced both battery cables and cleaned off the terminals. He fired up right away...it seems with a new attitude. Thanks for the input. We'll see if he keeps starting. Have a great week!
Thom Masterson
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | You can have the starter and alternator checked free at Auto Zone. they also have a thing you can buy too plug into the cigarette lighter too read the electrical system. not very expensive.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
