| | | Forums66 Topics128,115 Posts1,056,294 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 115 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 115 | I have two items that I'm having a tough time finding replacements. One is the fitting that screws into the master cylinder on my 56 Chevy 1/2 ton. I am including a picture. The threads are worn and it leaks. Second the spring that goes from the center frame rail to the emergency brake. It broke due to rust when I removed it during disassembly. Any suggestions on where I might find these items will be appreciated. I have exhausted all the parts stores in my area as well as trying Fastenal and Tractor Supply for the spring. http://i1142.photobucket.com/albums/n603/kennymartin2/IMG_2652.jpghttp://i1142.photobucket.com/albums/n603/kennymartin2/IMG_2653.jpgthanks, Kenny
Kenny Martin Talladega, Ala Second place is the first loser - Ricky Bobby 1956 Chevy 1/2 Ton | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you should be able to come close enough for the spring at a good hardware store, the splitter fitting isn't available other than used, but Weatherhead #7901 and 7727 together can be made to work [numbers from last time I got some at NAPA]
Bill | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you are desperate, I think the folks that rebuild masters could rebuild yours and supply the fitting. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | | | | | | Joined: Dec 2010 Posts: 115 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 115 | Thanks to all for the info. I believe the parts at Chevy of the 40s will work. Thanks for that link Alvin. I am headed to try to find a spring at the hardware store to make that work.
Thanks again for you help, Kenny
