0 members (), 41 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
#802997 12/03/2011 12:30 AM
I have two items that I'm having a tough time finding replacements. One is the fitting that screws into the master cylinder on my 56 Chevy 1/2 ton. I am including a picture. The threads are worn and it leaks. Second the spring that goes from the center frame rail to the emergency brake. It broke due to rust when I removed it during disassembly. Any suggestions on where I might find these items will be appreciated. I have exhausted all the parts stores in my area as well as trying Fastenal and Tractor Supply for the spring.
http://i1142.photobucket.com/albums/n603/kennymartin2/IMG_2652.jpg
http://i1142.photobucket.com/albums/n603/kennymartin2/IMG_2653.jpg
thanks,
Kenny
Kenny Martin
Talladega, Ala
Second place is the first loser - Ricky Bobby
1956 Chevy 1/2 Ton
you should be able to come close enough for the spring at a good hardware store, the splitter fitting isn't available other than used, but Weatherhead #7901 and 7727 together can be made to work [numbers from last time I got some at NAPA]
If you are desperate, I think the folks that rebuild masters could rebuild yours and supply the fitting.
1951 1 Ton Completed
Thanks to all for the info. I believe the parts at Chevy of the 40s will work. Thanks for that link Alvin. I am headed to try to find a spring at the hardware store to make that work.
Thanks again for you help,
Kenny
Kenny Martin
Talladega, Ala
1956 Chevy 1/2 Ton
