4 members (Shaffer's1950, artinva, Chip O, 1 invisible), 124 guests, and 3 robots.
Topics128,072
Posts1,055,903
Members48,429
#802887 12/02/2011 4:34 PM
I've been putting this job off for far to long but now it's time to replace the factory wires. Want a factory type that doesn't require a second mortgage. This is for my 53 3600 flatbed. I could go through it and repair bad areas but I think it's time for NEW.
Any ideas would be appreciate.
Jim
1946 1/2-Ton Chevy
Will you be using mostly original equipment?
Or, will you be adding electrical accessories (what)?
$150 will get you an excellent harness that will work with original equipment (but it will not be cloth-braided coverings).
Cloth-braided harnesses would cost $400+
This is all original with the exception that she's now 12 volt and I'm not worried about factory cloth insulation. Also can you recommend a vendor?
Also don't want a universal like I've seen with wires that are twice the length needed.
thanks
1946 1/2-Ton Chevy
Here are a 53-54 harness - Classic parts - one for use with a generator and one for use with a multi-wire alternator.
Jim Carter sells similar harnesses at a little higher prices - in Electrical - then with generator or with alternator.
For those wanting the cloth covering, just buy the taped type for about $150 and a roll of cloth tape for $35. It wraps easily and looks great.
I wonder if the original 6 volt wire might be a bit light for the 12 volt system.
~Jim
Ex Hall Monitor
Ex Hall Monitor
Quite the other way around. A six volt system draws a lot more amperage (double in fact) than a 12v. You'll need lighter wiring for a 12v system. For example Amps = Watts/Volts so using a 2336 (12v bulb) vs a 2330 (the 6v equivalent)- both use 26.5 watts so the 12 2336 would draw 2.2 amps while the 6v 2330 would draw 4.41 amps.
