8 members (NJC, cmayna, Hotrod Lincoln, lumbersawyer, JW51, 3B, cshades, 1 invisible),
100
Mod | | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I've been putting this job off for far to long but now it's time to replace the factory wires. Want a factory type that doesn't require a second mortgage. This is for my 53 3600 flatbed. I could go through it and repair bad areas but I think it's time for NEW. Any ideas would be appreciate. Thanks Jim
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Will you be using mostly original equipment? Or, will you be adding electrical accessories (what)?
$150 will get you an excellent harness that will work with original equipment (but it will not be cloth-braided coverings).
Cloth-braided harnesses would cost $400+
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | This is all original with the exception that she's now 12 volt and I'm not worried about factory cloth insulation. Also can you recommend a vendor?
Also don't want a universal like I've seen with wires that are twice the length needed. thanks
| | | | | Joined: Sep 2010 Posts: 72 New Guy | | New Guy Joined: Sep 2010 Posts: 72 | For those wanting the cloth covering, just buy the taped type for about $150 and a roll of cloth tape for $35. It wraps easily and looks great. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I wonder if the original 6 volt wire might be a bit light for the 12 volt system.
~Jim
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Quite the other way around. A six volt system draws a lot more amperage (double in fact) than a 12v. You'll need lighter wiring for a 12v system. For example Amps = Watts/Volts so using a 2336 (12v bulb) vs a 2330 (the 6v equivalent)- both use 26.5 watts so the 12 2336 would draw 2.2 amps while the 6v 2330 would draw 4.41 amps.
