| | | Forums66 Topics128,134 Posts1,056,406 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 11 'Bolter | | 'Bolter Joined: May 2010 Posts: 11 | I'm looking into buying a 51 Suburban project. I'd like to build it into something that I can get in and drive anywhere. My first question, is it possible to do that without putting it on an S10 chassis or is that the best way to go?
Second question, what parts go with the rear side windows? If the parts are missing what are the options?
Third question, are the running boards the same as on the trucks?
Any help would be much appreciated!!! | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | 1. There are about a thousand options and I would rate S10 chassis as about #843. It's been running on original suspension for 60 years and who knows where it's been but I would bet "Anywhere" is on the list.
2. Some of the burb owners will chime in I'm sure.
3. No, I think they are different but I may be proven wrong. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I don't know much about the s10 frame swap,a lot guys are doing it.I opted to rebuild my steering and suspension,brakes to stock standards.I'm still thinking about the front disc brake conversion.Another option I'm told adding a brake booster to the stock drum brake system makes a remarkable difference.I put a third member out of a 1958 1/2 ton Chevy with 3:90 gear ratio coupled to a 13-52-145 t5 s10 transmission.
As far as parts for the rear side windows,we need to see pictures to figure out what you're missing.Parts can be found,some take longer than others.They sell a one piece window kit as well,it eliminates the sliding windows"ebay truckman4787".
The 1/2 ton truck running boards are the same as the suburban.
I can drive my old suburban anywhere at anytime with no problems.It does really good on the highway and keeps up with traffic.
Tim
1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1. I use 3.55 ring&pinion conversion gears in the rear end and can cruise at 60-65MPH all day. I find my original brakes to work fine (ALL new parts in the brake system and front end and in front/rear suspension).
2. Post photos of what you have, as suggested by Tim, above.
3. Running boards are the same as on all 1/2 ton Chevrolet & GMC trucks from 1947-1955.
| | | | | Joined: May 2010 Posts: 11 'Bolter | | 'Bolter Joined: May 2010 Posts: 11 | Here's a link to what I'm looking at. No engine or trans, most of the glass is there but broken. Steering column is there but not in the pictures. I have a 235 laying around with a powerglide, have a 327 and a th350 somewhere. I would really like to go with something fuel injected though. I really want to build it reliable enough to be a daily driver, comfortable enough to throw the wife and kids in and drive a couple hours. http://s175.photobucket.com/albums/w143/jazn_84/Suburban/ | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I have driven my '54 burb over 10,000 miles this year with the stock six and stock suspension. It has a late '50s 3-speed OD and power front discs. I drove it to Phoenix, South Bend, El Reno, Kansas City and drove the Lonestar Loop 1000 through the Texas hill country as well as countless local shows and a 160 mile round trip to an Inliners meeting each month.
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I'm looking into buying a 51 Suburban project. I'd like to build it into something that I can get in and drive anywhere. My first question, is it possible to do that without putting it on an S10 chassis or is that the best way to go? Keeping the original frame has pro's and con's as already stated. It will drive like a truck with the original suspension or you can soften the ride by putting a modern front clip with a-frame and coils. Once you start modifying the frame you will have new options: power steering, disc brakes, tilt wheel etc. But keeping the original suspension also helps retain the value of an original burb, disc brakes can be purchased and some options can still be made.Second question, what parts go with the rear side windows? There are stainless handles and stainless window sweeps ( 1948/53 - 4 combination sweep/handles ) (1954/55 4 handles and 4 sweeps) If the parts are missing what are the options? Putting in a one piece window (especially if you put in A/C) or placing an ad in our swap meet section or looking on ebay etc. Third question, are the running boards the same as on the trucks? Yes, the 1/2 ton running boards are the same excepting for minor mounting differences.Any help would be much appreciated!!! That's a decent looking starter. The price is about right, but I would offer less because of some of the key missing parts and he has been trying to sell this for quite awhile. It looks like you will need a new gas tank if it has been sitting outside without a gas cap. Take this with you when you go to look at it. SUBURBAN/PANEL/CANOPY EXPRESS CHECK LIST Look in the gallery and some of the other sections to get an idea what has been done to these Suburbans. There are quite of few original parts still available for these and lot's of reproduction parts too. Completed project * Weeds Good post with pictures * pplummer Good luck! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....all good advice from guys who know! For my two cents I'd like to make a comment that we, or should I say "I", drive our vehicles in stop and go situations for hundreds and even thousands of miles. Why would we think we could not make a "two hour ride" at one jaunt?? Thats when they get lubed up and run good!! Just a perspective I have  | | | | | Joined: May 2002 Posts: 144 Shop Shark | | Shop Shark Joined: May 2002 Posts: 144 | Hey Achipmunk I agree!!! Drive it!!! Ter | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | s10/swapping frame Is #843, #1 Inspect and fix up with stock parts and drive, #2 add aftermarket, (built to function/look stock or be hidden) brakes, steering, wiring, bearings, etc. #3 (this one is for 55-59 and is my favorite), Add 73-87 front and rear axles and make it a 4x4 without changing frame. Changing frame has many, many problems adapting to all the stock systems, I.E. brake/clutch pedals, fuel tank, fuel filler, trans, steering, ebrake, body mounts, radiator, engine, bumpers, wheel fits into wheel well. I have done #1,#2 and #3 and studied #843(not for me, too hybrid) P.S. All my experience is on Suburbans and Panel trucks 55-59. Hope my analysis applies to AD. GMONIZ? where did he say price?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2007 Posts: 321 Shop Shark | | Shop Shark Joined: May 2007 Posts: 321 | I find with projects, the more you take on out of the gate, the less likelihood you'll have at completing it before you die.
The S10 frame swap is fine if that's what you want, but honestly, finding a clean and complete suburban would be more important to me unless you don't plan on using all of the factory original parts.
I guess it depends on what you want. Personally, I wouldn't do a frame swap unless my frame was rotten, and I wouldn't start with a rotten frame unless somebody gave me a complete truck.
