| | | Forums66 Topics128,083 Posts1,056,327 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 104 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 104 | I just read an ad on ebay where a guy claimed he had 19.5 wheels on the back of his '53 and Dodge 17" on the front. Will a late model 19.5 match the bolt pattern on these trucks ? I would be all for upgrading to tubeless radials.
1952 Chevrolet 6400 flat bed
| | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | Is your truck 10 bolt with 5 in front? There are 19.5" wheels in this pattern or if you can find them 22.5" wheels. I had some 19.5" that came off a step van. | | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | You might read through this http://www.stovebolt.com/techtips/wheels/The newer wheels are a regular conversation around here. Got a link to that Ebay Item, would like to see pictures of one with that combo.. Mongo | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | the truck pictured in the ebay link you included looks more like a 1 ton than a 1 1/2 or 2 ton. If so he would have been dealing with 8 bolt pattern and smaller diameter drums. I had a 48 1 ton and put 17.5 tubeless tires on front and 18" tube type on the back. Don't remember what the tubeless wheels came off. | | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | If you put the vin in the vin buster here on the stovebolt it coms up as a 1 ton | | |
