| | | Forums66 Topics128,024 Posts1,055,390 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Hello all, Man have I got one you you, This morning on my way to work My headlights started flashing on and off ? When I got to work I grabbed my meter and started checking out to see was the heck was going on of course it stopped doing it. but I cant figure out what happened, Any one ever had this happen before ? Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Yep, the circuit breaker in the headlight sawitch is cycling, either due to an overload somewhere, or a set of high-output headlight bulbs that are drawing too much current. Have you swapped to a set of halogen bulbs or something similar recently? If there hasn't been any change associated with the headlights recently, look for a short in the dimmer switch. Those things live in a nasty environment, and they're subject to getting partial shorts. If the C/B in the switch has cycled very much, it could have damaged itself and you might need to replace the switch. It's there instead of a fuse to prevent total loss of the headlights- - - -they flash, rather than just going out in case of a short. Jerry
| | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Thanks Jerry, I wasn't sure what was going on. Ive had Halogen since the build (07) but it happened once before when I first got it back on the road and then just stopped ? But that makes perfect sense,Is there a headlight switch with a higher duty cycle available ? Or is there any other way I can get around this ? I really like the high-output halogens. Thanks again Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | The circuit breaker is built into the headlight switch. It would probably be possible to disable that one, and add a slightly higher-capacity breaker inline with the power supply wire to the switch. The breaker is a bimetal strip that's visible from the top of the switch assembly, IMHO, and it can be wedged closed with a little ingeneuity. Be sure to add a slightly higher-capacity automatic-reset breaker if you choose to disable the built-in breaker. Good luck! Jerry
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | most folks recommend using a relay with higher draw lights, see hereBill | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Good idea ! I got several of them in my tool box that I've used on different applications on the 51. I don't know why I didn't think of that. Thanks Bill Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Install the relay,it's not complicated and the blinking light problem will be fixed.
Tommy 59 apache 1/2t 261 short stepside | | |
