2 members (VicZ, doyle1950), 143 guests, and 1 robot.
Topics128,087
Posts1,055,974
Members48,430
#801845 11/29/2011 5:49 AM
I replaced my old nonworking sending unit on my 51 with one that came with a set of gauges I got from a vendor and everything works great but I've had problems with the sending unit leaking from the mounting screws not from the gasket under the sending unit but from the screws ? I've tightened them and it's ok for a few days but then they start leaking again. The screws all have small o rings on them and for whatever reason I can't get them to seal, can anyone think of anything I can do to stop this ?
Hi, Clown. Two things come to mind, but not sure if either would work. Guess you'll have to try 'em and let us know. lol
There is a liquid thread sealant very similar to thread tape, but won't dissolve into the tank. A little bit of silicone might also work. Hope this helps. smile
Silicone will not stand up to gas.
You may want to try some Permatex #2 on the threads. It will stand up to gas.
Thanks I'll give it a try
Ditto on the Permatex. The stuff I used is called "High Tack Gasket Sealant". It had the no. 98H on the label, and also "item # 80062".
It seals the threads on the screws, and also never dries completely out, in case you ever need to remove them again. I used it on my F-350 and sealed the entire gasket with it.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Are you using a vented gas cap? I had this same problem when I bought a new vented cap, it held a couple of pounds of pressure, before the vent would open. I drilled a small hole in the vent, no more trouble.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
