1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 6 New Guy | | New Guy Joined: Oct 2011 Posts: 6 | I replaced my old nonworking sending unit on my 51 with one that came with a set of gauges I got from a vendor and everything works great but I've had problems with the sending unit leaking from the mounting screws not from the gasket under the sending unit but from the screws ? I've tightened them and it's ok for a few days but then they start leaking again. The screws all have small o rings on them and for whatever reason I can't get them to seal, can anyone think of anything I can do to stop this ? | | | | | Joined: Apr 2004 Posts: 438 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 438 | Hi, Clown. Two things come to mind, but not sure if either would work. Guess you'll have to try 'em and let us know. lol There is a liquid thread sealant very similar to thread tape, but won't dissolve into the tank. A little bit of silicone might also work. Hope this helps.  | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Silicone will not stand up to gas. You may want to try some Permatex #2 on the threads. It will stand up to gas. | | | | | Joined: Oct 2011 Posts: 6 New Guy | | New Guy Joined: Oct 2011 Posts: 6 | Thanks I'll give it a try | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Ditto on the Permatex. The stuff I used is called "High Tack Gasket Sealant". It had the no. 98H on the label, and also "item # 80062". It seals the threads on the screws, and also never dries completely out, in case you ever need to remove them again. I used it on my F-350 and sealed the entire gasket with it. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Are you using a vented gas cap? I had this same problem when I bought a new vented cap, it held a couple of pounds of pressure, before the vent would open. I drilled a small hole in the vent, no more trouble. | | |
