Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (TUTS 59), 45 guests, and 1 robot.
Topics128,009
Posts1,055,296
Members48,419
#801512 11/28/2011 4:24 AM
So I've decided to take the plunge and paint my truck myself. Looking at compressors and need to know what size to look for. Found a decent 23 gallon on Craigslist for a good price. Will this do?
Robert C.
I'm a Genius in the making.
1950 3600
Robert, AFAIK the main thing you want to look for is the CFM rating as well as tank capacity.
Obviously you don't want a compressor that can't keep up with the demand from your spray gun or other air tools.
It means the compressor would be running constantly to keep up.
Hopefully someone with painting expertise will confirm this.
More pix on Flickr.
Ex Hall Monitor
Ex Hall Monitor
This gets discussed a LOT. A search of the forum will get hours of reading on how to size a compressor. Here's a recent thread in the Tool forum.
Tiny #801667 11/28/2011 8:16 PM
Here is what Eaton has to say about their compressors. It is what I used to look for a compressor model that fit my needs.
COMPRESSOR PUMP
Eaton Pumps are built to last and are SUPER quiet in operation. This is because of our low pump speeds and compressor design. The EC31 Pump has all steel connecting rods with replaceable rod bearing inserts. This means our rods can be rebuilt and are not a throw-away. 99% of our competition (name brand) are using aluminum throw-away connecting rods with no rebuildable capability. The all cast iron crankshaft with ball bearings on the front and rear of the crankshaft create a smoother operating compressor and less drag and less electric being used. Removable 100% cast iron cylinders. This is more stable under heavy workloads and does not warp from heat like aluminum cylinders with a pressed-in sleeve. Most of our competition are using aluminum cylinders with a pressed-in sleeve. They are only good for 40-50% duty cycle and claim 100% duty cycle. In a year or so, most are replaced because they would not hold up under heavy use. All cast iron cylinder heads – NOT aluminum. Aluminum heads from heat will warp and cause head gasket problems. Cast iron head is more dependable and will last with trouble free operation. Intake and Exhaust valves are disk valve design. Most of our competition are using reed valves which are throw away and not rebuildable. Disk valves can be serviced in minutes instead of hours like reed valves. Our disk valves come out of the top of the head. Disk valves have been around for over 100 years. Our compression and oil rings are high quality and provide low oil carry over (1-5 pmm). Our pumps are precision ground pistons with tight tolerances for low oil carry over. We also use quality non-absorbent gaskets. This keeps oil seepage from coming off of the pump. This pump has an all cast iron flywheel with built-in fan– NOT aluminum. Aluminum does not give the proper throw when the pump is running. The extra weight of cast iron when running gives the pump more throw on the compression stroke and puts less load on the electric motor. Our crankcase is also all cast iron – NOT aluminum. All cast iron will give stable crankshaft alignment and will handle more work load under heavy load conditions. This pump has built-in intake head unloaders. These unloaders are built into the intake valve assembly on the compressor head. These unload or open the intake valves under constant run applications such as gas drive and electric units for constant run applications. This feature reduces internal pump heat from compression because the intake valve is held open under unloading cycle. It allows fresh air to come into the cylinder chamber but under compression stroke, the unloader holds the intake valve open allowing the air to blow back out the intake filter. This fresh air absorbs the heat out of the pump under heavy workloads. This pump includes a pre-cooling line that cools the air before it goes into the tank and also includes an all copper main feed line from the pump into the tank. This is copper for durability and not aluminum. We have one of the lowest RPM compressors on the market. This is critical. Many companies are lowering the quality of their product and running high RPM. High RPM causes high noise or db levels, lots of water in your airbecause the air is much hotter, lots of vibration and harmonic distortion, less belt wear, and most of all – longer pump life. Don’t cheat yourself…go low RPM and a BIG pump. Go Big or go home – you will be glad you did. Compare pump speeds from different manufacturers and you will see we are the lowest RPM. We can still give you high CFM with low RPM because our bore and stroke are bigger allowing us to run the pump slower causing less friction and heat buildup. Just remember…speed kills. Our competition is using small pumps that are noisy and high RPM. This is a recipe for pump failure.
RAISED MOUNTING PLATFORM
This platform is a nice feature for keeping your oil cool within the pump. This platform raises the pump approximately 2” off the mounting base plate. This allows 100% of the fan from the flywheel to circulate cool air not only on the sides and front of the crankcase, but also under the crankcase as a constant flow of air. This feature gives your pump cool oil - - cooler oil not only helps to lubricate the pump but pulls the heat off the pistons and connecting rods. This will add many years of life to the compressor pump.
BELT TENTIONER
This unit includes an auto belt tentioner. If you have ever tightened belts on your compressor, you will know without a belt tentioner that it is almost impossible to get the correct belt tension and keep your belts in alignment. With our unit, this is not a problem anymore. Just loosen the 4 bolts under the motor about 2 threads and take a ¾” wrench and turn the bolt on the end of the tentioner and your belts are tightened and perfectly aligned. This makes maintenance happen in a few minutes and it is done correctly.
BELT GUARD
We manufacture our belt guards tougher than any you will find today. Many are using plastic or a bird-cage style belt guard. This is a cheap way of building a belt shield and is not durable. Our belt guard is made out of 13-gauge material and is all OSHA approved.
AIR TANK
Our tanks are ASME code American Made air receivers. This tank meets codes in all 50 states including California.
CONTROLS & COMPONENTS
Top quality pressure switch with adjustable screw to adjust your pressure higher or lower. Our check valves are all brass with a Teflon seat. This makes low tank noise when the compressor is running because Teflon is much quieter when opening and closing during the compression stage. All brass ASME code safety valve is used for your safety. Our valves are preset and sealed for correct settings. If your compressor would not turn off, our safety valves will open and keep from building too high pressure and potentially keeping the tank from rupturing. Top quality plumbing fittings are used to maintain proper sealing when connected to the tank. High quality all brass ball valve is used for turning air on and off from the air receiver. Tank water drain pipe plumbed out the front of the unit with a ¼” ball valve handle for easy tank draining without the hassle of draining the tank with a petcock under the tank. Loadless starting is built onto this unit. This unloads the pump so the pump will not start under direct head pressure. Without this feature, this will cause motor damage under starting cycle.
CONTINUOUS RUN & AUTOMATIC START/STOP
Under heavy workloads such as sandblasting, your compressor can cycle on and off many times per hour. This cycling is causing the magnetic contacts more wear because they are arching as they start and stop. A single phase motor also is arching because it has start and run windings built inside. When the motor is starting, it is on the start windings. The capacitors shoot 580V of power to the motor windings to start. As the motor gets to full RPM, there is a centrifugal switch that switches it from start to run windings. Every time this is done, your contacts are arching from start to run procedure. That is why the continuous run is good because under workloads over 50% duty cycle, it eliminates this arching and wear and tear on your magnetic contactor. The other reason is because under applications such as poly foam insulation trucks, their generator cannot handle the starting and stopping loads, so the continuous run is a better way to go under this type of application. Then when you are back into normal workloads in your shop, you can turn off the continuous run and the unit will go to automatic start/stop feature. It will just start and stop like a normal compressor.
STARTER SWITCH
With heater overload
MOTOR PULLEY& BELTS
Our pulleys are 2-groove and not 1-groove. You will see many compressors only using 1 belt to drive the pump. This unit uses 2-groove, B-Style belts. This ensures long belt life and low vibration and makes a quieter unit because the belts do not have to be so tight to drive the pump. The tighter the belts, the more load on the compressor pump bearings and the motor bearings and decreases the life. Our pulleys are taper lock design. This is much better than a fixed bore with a set screw. A taper lock will lock the pulley in position to the motor shaft allowing it not to loosen or move on the shaft. Our belts are also top quality and will last many thousands of hours of running.
