4 members (HandyAndy, David Bush, joe apple, 3B), 70 guests, and 1 robot.
Topics128,050
Posts1,055,753
#801565 11/28/2011 1:54 PM
I am in the process of painting the door panels of my 46'. Before I stripped them I noticed a wear line on the lower portion of the panel. Is there some type of seal that is missing to keep the paint from wearing a line on my newly painted panels.
I've noticed this on other trucks for sale as well. Thank you.
...if it is like my 37, and it sounds like it is, there is a rubber strip that attaches to the lower section of the cab and goes against the door when it shuts and seals it.
...just as info. My door panels were so beat up I covered them with some thin foam and fabric. When I closed the door the rubber strip let a "mark" on the fabric and it also caused the door to bulge just a little. I knew my doors did not, and have not, shut the best since I did the truck. So, I ended up taking a razor blade and just cutting/trimming the cotton picking rubber seal off. The doors shut better then!
Moderated by  ndkid275, Phak1
