2 members (blanch53, Materman),
111
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 50 | Is there a good easy rearend to swapout over the torque tube.I have a 52' 3100. I just wanna go to a open rearend. | | | | | Joined: Apr 2011 Posts: 23 New Guy | | New Guy Joined: Apr 2011 Posts: 23 | I used a 1967 Chevy half ton in mine, was the right width and has the 6 lugs. just had to weld spring perches on. pretty easy swap. here is a link to some others that might fit as well http://www.chevytalk.org/fusionbb/printpost.php?tid/173541/I also used the t-5 transmission swap that was much simpler than all the info out there would lead you to believe . John | | | | | Joined: Jan 2009 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 106 | The "good easy" rear end swap for your 52 3100 would be a 1/2 ton rear end of the right width and six lug pattern matching your existing wheels. A rear end that only requires welding new spring perches as digg said (and a drive shaft). Beginning with the 1955 1/2 ton, the rear ends were open drive. I had a 1955 rear end in my 54 3100 for years and switched to a 1965 1/2 ton rear end when the 55 wore out. Think about the gear ratio you would like to have before you buy a rear end because you can save money and hassle buy getting the right ratio without changing the ring and pinion gears later. My 1955 rear end had a 390 ratio which was a good compromise between high and low end. The 1965 has a 373 ratio which is good on the highway but a little high for heavy low end pulling.
Stovebolts are good for the heart
| | | | | Joined: Aug 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 50 | I was just wondering if there was a "bolt on",spring pads in place. | | | | | Joined: Jan 2009 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 106 | I do not know of a "spring perches in place" rear end because the location of the perches was changed with the introduction of the open drive. Maybe a bolter will chime in if they have an answer? You might consider posting an ad in the Parts Wanted Forum for a rear end that someone has already made the changes in the location of the perches. Someone might be parting out a truck or swapping out a drive line. You could also post a message in this Forum asking if anyone in your area knows of someone experienced in moving the perches, who works at a reasonable rate.
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Is there anything wrong with your stock setup? Why change?
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Aug 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 50 | other than 35 to 40 mph top speed nothin,goin to a sbc. | | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | i have a 1954 gmc,junked the old rearend put a 1972 pickup under it.direect bolt in.took about 1hour to do the job..338gears,5lug. | | |
