1 members (Phak1), 48 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#801159 11/27/2011 1:08 AM
Is there a good easy rearend to swapout over the torque tube.I have a 52' 3100.
I just wanna go to a open rearend.
I used a 1967 Chevy half ton in mine, was the right width and has the 6 lugs. just had to weld spring perches on. pretty easy swap.
here is a link to some others that might fit as well
http://www.chevytalk.org/fusionbb/printpost.php?tid/173541/
I also used the t-5 transmission swap that was much simpler than all the info out there would lead you to believe .
The "good easy" rear end swap for your 52 3100 would be a 1/2 ton rear end of the right width and six lug pattern matching your existing wheels. A rear end that only requires welding new spring perches as digg said (and a drive shaft). Beginning with the 1955 1/2 ton, the rear ends were open drive. I had a 1955 rear end in my 54 3100 for years and switched to a 1965 1/2 ton rear end when the 55 wore out. Think about the gear ratio you would like to have before you buy a rear end because you can save money and hassle buy getting the right ratio without changing the ring and pinion gears later. My 1955 rear end had a 390 ratio which was a good compromise between high and low end. The 1965 has a 373 ratio which is good on the highway but a little high for heavy low end pulling.
Stovebolts are good for the heart
I was just wondering if there was a "bolt on",spring pads in place.
I do not know of a "spring perches in place" rear end because the location of the perches was changed with the introduction of the open drive. Maybe a bolter will chime in if they have an answer? You might consider posting an ad in the Parts Wanted Forum for a rear end that someone has already made the changes in the location of the perches. Someone might be parting out a truck or swapping out a drive line. You could also post a message in this Forum asking if anyone in your area knows of someone experienced in moving the perches, who works at a reasonable rate.
ODSS Lawman
ODSS Lawman
Is there anything wrong with your stock setup? Why change?
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
other than 35 to 40 mph top speed nothin,goin to a sbc.
i have a 1954 gmc,junked the old rearend put a 1972 pickup under it.direect bolt in.took about 1hour to do the job..338gears,5lug.
