3 members (MickeyP, 2-Ton, 1955 1 Series), 122 guests, and 1 robot.
Topics128,115
Posts1,056,624
Members48,450
#800488 11/24/2011 2:13 AM
I will be putting a new box/bed on my pickup, and I'm wondering about the best procedure for painting it. Should I: 1) prime and paint the metal box pieces before assembling them, 2) assemble them first and then prime and paint, or 3) prime the pieces, assemble them, and then paint? Thanks for the input.
My toys:
'41 Chevy Model AL 3/4 Ton
'40 Chevy Model KD 3/4 Ton
Hinomoto 209N Tractor/Backhoe
Norwood LM2000 Sawmill
PJ 16' Trailer
and a Brand New Shop!
Be what you is, not what you ain't, 'cause when you is what you ain't, then you ain't what you is.
..... I like to paint and then put together. I think it makes the "details" look nice and clean.
I trimmed mine then assembled, at that point I re-painted the whole thing. Last but not least I then painted then inside with a spray on bed liner.. if you gonna use the truck I highly recommend the liner.. enjoy and good luck.
Kent
1953 1/2 ton Chevrolet
I painted mine apart. Because I used polished SS bolts and didn't want them painted. I might add that I assembled the entire bed first to check fit then primed and painted.
I'm like Kent. I trim everyting scuff it back down then assemble and refinish. this way everything is sanded completely and theres no chance of paint peel along the edges. It also gives you good coverage where the panels bolt together and reduces any risk of bare metal rusting. Keep in mind, even if your ride never gets driving in the rain, the temps outside still change and can cause condinsation in places that typicaly would never get wet. you want to protect everytihng.
1949 chevy 3100
Skip49 #801728 11/28/2011 11:18 PM
You just described the conditions in my garage.
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
