Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Crimson48, TUTS 59, Phak1, Gdads51, 1 invisible), 48 guests, and 0 robots.
Topics128,007
Posts1,055,278
Members48,418
#79979 07/13/2007 8:13 PM
If you followed my saga you know that I have bent 2 push rods. I have been successfully in unsticking one of 2 valves and will unstick the other this weekend and hopefully bring this girl back to life. (fingers crossed). My question is, Is there a difference in push rods for the 235? I have seen this stuff about hydrolic lifters and I am not sure if I have those are not and if it makes a difference with the type of push rod that I buy. The folks at NAPA althought nice, dont know much either.
Block number is 3764476 and Head casting # is 3836848. I think I have a 57 Head and a 58-62 block if that helps anything.
#79980 07/13/2007 8:54 PM
To the best of my knowledge the pushrods are the same length. None of my books show a different part number.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#79981 07/13/2007 9:38 PM
Purney,
I don't know about the pushrods but as Dave said, I think they are the same for solid or hydraulic lifter. The important thing will be to determine which lifter you have so you can adjust it/them properly. Pulling the side cover would provide a visual ID and is probably the best method.
Stuart
#79982 07/13/2007 9:49 PM
Great info, next question then, what visually tells you they are hydrolic lifters?
Thanks Guys.
#79983 07/14/2007 12:22 AM
0.426 ROD, Valve Push
Parts catalog listings thru 1957
ARE HERE
Not sure where to find the later years.
-Tom
1950 Chevy 3100 w/ 1956 235
