| | | Forums66 Topics128,005 Posts1,055,253 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79979 07/13/2007 8:13 PM | Joined: Apr 2007 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 82 | If you followed my saga you know that I have bent 2 push rods. I have been successfully in unsticking one of 2 valves and will unstick the other this weekend and hopefully bring this girl back to life. (fingers crossed). My question is, Is there a difference in push rods for the 235? I have seen this stuff about hydrolic lifters and I am not sure if I have those are not and if it makes a difference with the type of push rod that I buy. The folks at NAPA althought nice, dont know much either.
Block number is 3764476 and Head casting # is 3836848. I think I have a 57 Head and a 58-62 block if that helps anything. | | |
#79980 07/13/2007 8:54 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | To the best of my knowledge the pushrods are the same length. None of my books show a different part number. | | |
#79981 07/13/2007 9:38 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Purney,
I don't know about the pushrods but as Dave said, I think they are the same for solid or hydraulic lifter. The important thing will be to determine which lifter you have so you can adjust it/them properly. Pulling the side cover would provide a visual ID and is probably the best method.
Stuart | | |
#79982 07/13/2007 9:49 PM | Joined: Apr 2007 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 82 | Great info, next question then, what visually tells you they are hydrolic lifters?
Thanks Guys. | | |
#79983 07/14/2007 12:22 AM | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | 0.426 ROD, Valve Push Parts catalog listings thru 1957 ARE HERE Not sure where to find the later years.
-Tom
1950 Chevy 3100 w/ 1956 235
