1 members (Hotrod Lincoln), 130 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#799244 11/19/2011 9:27 PM
It has no stampings. I believe it is GM. It's in a 1949 Chevy.
https://picasaweb.google.com/106959952217522043008/20111119#5676805315270518434
Probably not that old, what are the casting numbers on it?
Bruce
My Trucks
Stuff I Collect
There are none, But I have pics of all the parts that came out of it.
3B Offline
Hy hasson, it might be a 3/4 - 1 ton rear diff., used from the forties to the sixties. I can't see all the mounting holes in the pic. but the diff. I'm thinking of has ten mounting holes.
reo Offline
did they make a 10 or 12 hd rear end that came out the front i think it also had arear cover
It looks like the standard 1 1/2 - 2 ton rear end used in a ton of years of both Chevy and GMC trucks. It doesn't have a specific name for that axle type.
What size truck did it come out of?
Jeff
My 1953 Chevrolet
1947.1 Gallery
1949 Chevy 4400.
I found a 5.14 out of the same year GMC. Does anyone know if it will fit?
If it came out of the same type of carrier, it should fit. There were a few slightly different axle housings that shared most of the same parts for the carrier itself. Some had different axle shafts and side gears but most of the time the carrier and ring and pinion gears were the same with the exception of Timken and other brand rear ends plus 2 speeds.
BE SURE to measure the backlash of the ring and pinion gears before tearing it apart. If the tolerances are reset back to stock those gears will whine and wear fast.
Jeff
My 1953 Chevrolet
1947.1 Gallery
As I posted above, before realizing the actual ratio, if the carrier is the same, it should fit. Unfortunately the 5.14 is from a 1 ton truck and will not fit. The carriers look identical, but the 1 ton is much smaller. They did not make a 5.14 for 1 1/2 ton rear ends.
Jeff
My 1953 Chevrolet
1947.1 Gallery
The main pic is on its side- right? So that the crown wheel overload screw is facing up.
It looks identical to the one in my '47 1.5 ton (4100, more or less).
mine is MASSIVE, 12 inch crown wheel, 5.54 ratio, on an axle with 11000 lb springs and dual 7.00-20 wheels.
From what I know, (not much) all the big bolts from the early 40s to the mid 50s had the same unit with varying ratios, 5.54 and 6.11 were common.
No stampings, vague casting numbers between the top ribs.
Rich
'47 Canadian RHD 1.5 ton truck
