3 members (KCMongo, HelmutVonSchet, 59 fleet), 90 guests, and 0 robots.
Topics128,049
Posts1,055,679
#797961 11/15/2011 12:09 AM
When I originally checked out my '64 C10, I brought along my father-in-law. He is a '61 year old ASE certified tech that has actually owned a '65 C10.
When the truck was first started, until it got warmed up, the was this loud, intermittent, whinning/rubbing noise coming from under the hood, mostly pronounced on the drivers side. He told me he thought it was the old alternator... So, I wasn't too concerned. Two days ago, I did a motor flush. Since then, it has gotten louder and more persistant. It ALMOST sounds to me like there is something in the motor that isn't getting any oil. Sounds kind of like something metal, rotating against something else metal, with no lubrication.
Any thoughts or suggestions on what could be the actual cause?
'64 C10 Long/Fleet, 230ci w/4 on the floor
Inline 6 or V-8?
First thing I would do is remove the v-belts and start it up. If the noise is gone then it is either the alternator or the water pump (or the power steering pump if so equipped).
If the noise persists I'd pull the timing chain cover and inspect it for wear.
Hope that helps. thumbs_up
Does it change when you push the clutch in?
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
It's GENERALLY only heard at idle... But, I have heard it while driving. Does NOT go away with the clutch pushed in.
Originally Posted by Hot Rod John
Inline 6 or V-8?
Thanks for the ideas. That's EXACTLY what one of my co-workers just suggested this morning. I'll be sure to check that.
Be sure to let us know what you find out.
Not to hijack, but be sure to let us know what it is. My truck periodically (like once every couple months) makes a god awful high pitched wailing/rubbing noise just like you described.
I find if I bring the truck to a stop and hit the brake pedal, it goes away after about 5-10 seconds and stops completely until the next time.
It sounds like its coming more from the bell housing/tranny though.
Is there anything turning when the truck is sitting still idling that the brakes would affect when pressed?
Assuming you are sitting there with the clutch pushed in, I would guess throw out bearing or piolet bushing.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
I've been EXTREMELY busy, so I haven't been on in a while. The noise turned out to be the alternator. About a week after posting this, it seized up completely.
I had the same problem on my last road trip to Connecticut.
Had the alternator rebuilt, and it has been fine since it was done.
I heard that once.....made a screech sound that would raise the dead.
That turned out to be a bad rod bearing.
We emory papered the journal and put the same bearing back on it, it went another 2 years with daily use. hard to believe, but true.
64 & 66 GMC long fleetside 4x4
Cartwright, OK
On my '54 1/2 ton, I have a awful metal on metal sound when de accellerating (gearing down). It goes away if I push and hold the clutch in.
Any thoughts? I was thinking the throw out bearing.
When I saw the title of this thread, I thought "what the hell is that guy doing in my kitchen while my wife is cooking dinner?"
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
