6 members (TUTS 59, Ponchogl, Steelonsteel, Gdads51, Gray_Ghost, ESum), 92 guests, and 4 robots.
Topics128,088
Posts1,056,125
Members48,435
#789938 10/18/2011 8:56 PM
anybody had dealings with or good knowledge of 347 v8 gmc /pontiac
as i,m considering buying a truck with one in
what is the power like?
are they reliable?
are they tunable ?
any comments positive or other ??
live or die do it with spanner in hand
spanners #790088 10/19/2011 4:28 AM
3B Offline
Hy spanners, the Pontiac/GMC V8s were/are very reliable, the engineers at GMC had their pick of GM engines for the light/medium duty truck line, and they chose to use the Pontiac engine over all the others. Are they tunable, of coarse they are, they just require a little more research than the small block Chevy, to tell you what interchanges, and what works well, hope that helps.
3B #790116 10/19/2011 9:14 AM
No experience with the 347, but I had a 1958 336 in my 1959 gmc when I got it. The 336 is basically the same engine as the 347. It was a very reliable trouble free motor. I have since replaced the 336 with a 1959 pontiac 389, which I have had bored and stroked to 447 inches. 1955-1959 pontiacs are vitually interchangeable as far as dimensions and mounts go. A 1960 pontiac will also bolt up to the hydramatic transmission. The timing cover is different on the 1960 Pontiac as the 1960 motor is not "reverse cooled like the 1955-1959 pontiac and gmc v8 motors.
Here's an interesting link with hp and torque specs. http://enginefacts.com/pontiac347.php
1 Offline
The Pontiac 347 was a great endurance engine. I saw them give 150,000 trouble free miles of service when the proper oil change and tune-up intervals were observed. There is a '57 Pontiac Chieftan two door post here that has the factory Tri-Power setup and it still is a very dependable and fast engine. The only changes I'm aware of is the change out to a HEI and some carburetor modifications. The 287, 316, 347, 370, 389, 400 and 421 were all excellent engines in my opinion.
Normbc9
