0 members (),
136
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | anybody had dealings with or good knowledge of 347 v8 gmc /pontiac as i,m considering buying a truck with one in what is the power like? are they reliable? are they tunable ?
any comments positive or other ??
live or die do it with spanner in hand
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy spanners, the Pontiac/GMC V8s were/are very reliable, the engineers at GMC had their pick of GM engines for the light/medium duty truck line, and they chose to use the Pontiac engine over all the others. Are they tunable, of coarse they are, they just require a little more research than the small block Chevy, to tell you what interchanges, and what works well, hope that helps. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | No experience with the 347, but I had a 1958 336 in my 1959 gmc when I got it. The 336 is basically the same engine as the 347. It was a very reliable trouble free motor. I have since replaced the 336 with a 1959 pontiac 389, which I have had bored and stroked to 447 inches. 1955-1959 pontiacs are vitually interchangeable as far as dimensions and mounts go. A 1960 pontiac will also bolt up to the hydramatic transmission. The timing cover is different on the 1960 Pontiac as the 1960 motor is not "reverse cooled like the 1955-1959 pontiac and gmc v8 motors. Here's an interesting link with hp and torque specs. http://enginefacts.com/pontiac347.php | | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | The Pontiac 347 was a great endurance engine. I saw them give 150,000 trouble free miles of service when the proper oil change and tune-up intervals were observed. There is a '57 Pontiac Chieftan two door post here that has the factory Tri-Power setup and it still is a very dependable and fast engine. The only changes I'm aware of is the change out to a HEI and some carburetor modifications. The 287, 316, 347, 370, 389, 400 and 421 were all excellent engines in my opinion. Normbc9 | | |
