2 members (baldeagle, Forty9),
23
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Here's a little tech tip to see timing marks better. It's not a new idea, especially among model builders and possibly some of you have already utilized it. Take some bright acrylic paint and a small brush and paint over the timing tab covering the indented timimg marks. Let it try about 30 seconds, than wipe away the excess with a tissue leaving the paint in the marks. It might take a couple of coats to get it right. I did this on a 292 I am freshining up. See the end result pic. This will work on the balancer mark too. [IMG] http://pic100.picturetrail.com/VOL1061/3611363/23917335/399525829.jpg[/IMG]
Drew
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Thanks but that won't be much help on a 216-235-261 since there is no tab. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That tip can be used on the 216/235/261, just in a different way. Paint the pointer in the window a bright color (I used flat white) and perhaps a dab on the BB on the flywheel. Makes them much easier to see.
Bill Burmeister | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | That tip can be used on the 216/235/261, just in a different way. Paint the pointer in the window a bright color (I used flat white) and perhaps a dab on the BB on the flywheel. Makes them much easier to see. You are right. I should have mentioned that too.
Drew
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | yeah the older I get the more I need easier to see...
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I needed the easier to see white-marked ball/"BB" in 1969 when I was little more than a boy - this was necessitated by the cheap timing light that I was barely able to afford.
