0 members (), 46 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#798135 11/15/2011 4:05 PM
Here's a little tech tip to see timing marks better. It's not a new idea, especially among model builders and possibly some of you have already utilized it. Take some bright acrylic paint and a small brush and paint over the timing tab covering the indented timimg marks. Let it try about 30 seconds, than wipe away the excess with a tissue leaving the paint in the marks. It might take a couple of coats to get it right. I did this on a 292 I am freshining up. See the end result pic. This will work on the balancer mark too.
[IMG]http://pic100.picturetrail.com/VOL1061/3611363/23917335/399525829.jpg[/IMG]
Drew
DrewP #798156 11/15/2011 5:45 PM
Thanks but that won't be much help on a 216-235-261 since there is no tab.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #798202 11/15/2011 8:10 PM
That tip can be used on the 216/235/261, just in a different way. Paint the pointer in the window a bright color (I used flat white) and perhaps a dab on the BB on the flywheel. Makes them much easier to see.
Bill Burmeister
LONGBOX55 #798217 11/15/2011 9:25 PM
You are right. I should have mentioned that too.
Drew
DrewP #798301 11/16/2011 3:29 AM
yeah the older I get the more I need easier to see...
brokenhead #798306 11/16/2011 3:39 AM
I needed the easier to see white-marked ball/"BB" in 1969 when I was little more than a boy - this was necessitated by the cheap timing light that I was barely able to afford.
