1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 101 | Wondering if anyone has ever had a whistle sound come from their carb? My Rochester B makes this whistleing sound as I accelerate. I recently replaced my carb. and the noise started with the new carb.
Disciple
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | a vacuum leak.a port not connected or not blocked off.Maybe not sealing around the base | | | | | Joined: Jan 2009 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 101 | Yesterday afternoon I tightened everything on the carb. While running the engine at idle I sprayed carb cleaner around the intake manifold and the base of the carb. As I sprayed, and on the right side where the manifold, gasket and carb base sit, I would notice that the engine would slow and stumble. I believe this is saying I have a leak in this area. Am I correct?
Disciple
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | | | |
