4 members (Otto Skorzeny, FAST55, Hawkman, 52GMC35424JD), 91 guests, and 1 robot.
Topics128,051
Posts1,055,768
#797405 11/13/2011 3:28 AM
Wondering if anyone has ever had a whistle sound come from their carb? My Rochester B makes this whistleing sound as I accelerate. I recently replaced my carb. and the noise started with the new carb.
Disciple
Ted W #797435 11/13/2011 4:55 AM
a vacuum leak.a port not connected or not blocked off.Maybe not sealing around the base
BC52 #798094 11/15/2011 11:57 AM
Yesterday afternoon I tightened everything on the carb. While running the engine at idle I sprayed carb cleaner around the intake manifold and the base of the carb. As I sprayed, and on the right side where the manifold, gasket and carb base sit, I would notice that the engine would slow and stumble. I believe this is saying I have a leak in this area. Am I correct?
Disciple
Ted W #798096 11/15/2011 12:00 PM
yes
