4 members (dogdaddy, Ponchogl, 2-Ton, 1 invisible), 72 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
#797592 11/13/2011 10:43 PM
any one have good luck with pertronix? I put one in my mustang it died within 10 minutes. Put one in my truck it ran great, so today I finally got my wife to go with me and the ignition took a dump had to take a bus home and get my original set up. (not really sure why it wasn't in the glove box.) Along the same lines, my tiny tach now reads 1600, all the time...I still don't know what RPM I am running on the freeway. I know they can make electronic devices that work, and work well. but apparently it is too much trouble to charge some one $150 for something and actually expect it to work...Whatever the case, it will probably take 3 more years to get my wife near that truck again.
What year and voltage/ground truck?
Sounds like you have some electrical problems.
Is your wiring in good shape?
Do you have clean grounds in original locations?
I have had one 12v Pertronix unit working fine in a 1954 Chevy pickup since 1997.
I have one 6v Pertronix unit working fine in a 1954 Chevrolet Suburban since about 2004.
Try a search on the site on "Pertronix".
I carry a complete, tested, spare distributor with a points-system in it. This is good insurance (that I have not yet had to use).
Yes....I also have had good luck with my installation on my 235 !!
I have had it for 2 years and have yet to have a issue. Its my Daily Driver and works every day.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
I have installed several and no problems yet.
If you want electronic ignition, install a GM HEI system and forget about it. Pertronix is a crapshoot- - - -some work and other's don't.
Well for now I'm sticking with the points, they have worked on this truck for the 27 years I have had it. I've never been stranded until now. I mean the pertronix worked great for about a year (?) but that makes two that have quit on me. I am getting a little gunshy, I'm trying to get another engine built, but I am spending all my time trying to keep the old one running. And when the "improvements" set me back it kind of p###### me off, at least you can set the points with a matchbook cover. I'm just glad it wasn't raining. I certainly hope I can find the receipt...
I've seen an article recently that details how to use a 6-cylinder Mopar distributor trigger and a GM HEI module to convert the Stovebolt distributor to a stock-appearing electronic ignition system. It uses all over-the-counter parts available at the FLAPS and seems to be very reliable. I'm going to have to look into that one a little more closely.
Thats why I keep the original points in mine,I keep a spare set in the truck and I never had to use them yet.KISS principle.
Pete
Big Bolt Forum Co-moderator
I like that idea. I have learned to distrust electronics. One morning I went out to start my 2002 Dakota and it cranked but wouldn't start. Turns out it was the "crank angle sensor" that evidently tells the computer to send the juice to spark plugs in place of having points. (excuse my ignorance). Well in the old days if my points burned out or needed adjusting I could do it with a pocket knife and a matchbook. If this sensor faied when I was on top of a BC mountain trout fishing I would have a long walk home. I know it must give one a lot better gas mileage and power, and saves the ozone layer, but I like the idea of points. I also like old movies and TV shows. : ) The idea of having the distributor back up is great.
1948 Chevy 2-Ton
I'll also weigh in on the side of keeping the points. I have had one truck (daily driver) for 18 years that has never let me down using the stock points. I can't say the same for trucks I've had with black box technology.
I also carry a spare set w/ condenser in the glove box and have never needed them. Adjust and or replace your points according to your scheduled maintenance and you'll have a trouble free truck.
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
Now that might be interesting to me, do you have an article reference Jerry?
Sort of stock 1950 Chevrolet 3100
235 (The engine shread) (Engine assembly)- 4 speed - 12 bolt - stock front axle with power disc brakes
I have pertronix in the '40 for seven years now , all good and pertronix in the Bedford for 4 yrs also , all good.
Dusty #797772 11/14/2011 12:48 PM
well I've had two of them quit on me. One in the mustang, and this one. I even bought their special coil. You might get 3 strikes in baseball, but 2 is all I'm giving. I know electronic ignitions work well, I was trying to keep the stock distributor, but not if it means walking...
Dusty #797773 11/14/2011 12:53 PM
Ringleader,
I saw the article about the conversion with the chrysler pick up and gm module on the hamb site. The guy that does it is in indianapolis, I spoke with him briefly and seems like a neat item. I just never followed through. I have petronics and have had no problems with it.
Tommy
59 apache 1/2t
261 short stepside
Tommy #797811 11/14/2011 2:40 PM
I had one in my 54-3100 for 7 years no problems but i put one on my 1960 MGA and it did not last the first start, it blew apart at the back.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I believe it was on the HAMB site, but I quit going there a long time ago- - - -can't stand the obnoxious donkeyholes who hang out there.
It doesn't appear to be hard to do, but it does involve a little machining on the distributor cam to make the magnetic trigger fit. I'm going to set the cam up in my lathe and use a tool post grinder to get a snug fit, and maybe use epoxy or red LocTite to hold it in place. The trigger coil is mounted to the breaker plate with one or two screws and adjusts like a set of points to about a .020" gap, and the signal goes to the same terminals that are used for the pickup coil on a GM HEI distributor. It's necessary to build a sheet aluminum bracket to act as a heat sink for the module, but it can be put anywhere in the engine compartment there's airflow to keep it cool. I believe it uses the same E-coil as the remotely-mounted coils used on the 6-cylinder Chevy HEI system.
The good part about that one is the fact that repair parts are all available at a pretty good FLAPS like NAPA.
I installed Pertronix in my 53 about a year ago with high expectations. I took it out two weeks ago and am delighted to have a truck that starts well again. I am one who tends to blame the installation instead of the product, but this pertronix unit completely gave up in the end.
It may not be the easy way, but it is the Cowboy Way - Ranger Doug
Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri
1953 Chevy 3100
1960 Volvo PV 544
1941 Chevrolet Special Deluxe
I sold the Pertronix units for about 12 years while working for an auto parts store. I only remember one unit ever coming back. All the ones I have installed are still going and have not had any problems. Guess I got very lucky.
well after about 2 hours of searching, I finally figured out where I got it from and am getting an email copy of my invoice to return the module.
I installed a Pertronix in my 1954 pick up with 235 and 12 volts about 6 years ago and have not had any problems. The instructions that come with the Pertronix say the unit may be damaged if the ignition switch is left in the on position without the engine running. The tech support at Pertronix says the original model Pertronix (with black ignitor)is the one that may be damaged with the ignition left in the on position. The Pertronix model II and model III will cut off to protect the unit if the ignition is left on. The model II has a red ignitor. The model III has a black "flat" ignitor that looks different than the other models. Tech support says a tach should work with Pertronix and to check that the connections are clean and tight. Tech says if the tach works but rpm"s seem to be off then a diode or resistor should be installed in series between the coil and tach. The reason I installed a Pertonix is just to avoid the extra maintenance of installing points and timing. I have not noticed any improved performance from the Pertronix and Flame Thrower hot coil combination.
Stovebolts are good for the heart
I turn the ignition off otherwise it just keeps running. The tiny tach just use a wire wrapped around the coil wire, it has nothing to do with the ignition. Whatever the case as soon as my invoice shows up I'm sending it in for replacement the tiny tach is just going back...
