| | | Forums66 Topics128,214 Posts1,057,488 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 138 | Ok guys. I've got my 1950 Chevy 6400. It's got an unidentified motor in it with fairly loud rod knock if you rev it up much without a load.
It's got the two acorn style nuts that hold the valve cover down. Is it a 216 or 235? It does not have the side cover extending up over the spark plugs. The exhaust outlet angles to the rear a little bit.
Just curious. The truck is gonna get dieselized eventually, but still wouldn't mind know what this is.
Thanks!
-Matt
-Matt
| | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Sounds like a 235... Best thing to do is find the casting number on the block. It should be on the side below the distributor. Take that to the Inliners Casting Number page linked in another thread here in the Engine Bay. CTRL-F is your friend for that one. (find on page)
That page will tell you what size, what year and maybe a few other things about your engine (or at least the block).
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It is most likely a splash 235. In 1950-52 the big trucks got the same engine as the Power Glide car engine except with solid lifters.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | We had a '50 Chevy 6400 truck for the ranch. It had a 235 with a internal setup using the old 15 lb oil pump but had rod insert bearings. It ran like a top and gave us some really good long term service. While some give this engine a "Splasher" description it really is a "Spray" oiling system. When I did go into it I replaced the oil pump and siphon with a non-Power Glade '53 Chevy pump. It raised the oil pressure on the gauge a bit. I still see it running almost every week when I go to town. Normbc9 | | | | | Joined: Aug 2008 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 138 | Ok. Cool. Yah, oil pressure runs about 15psi when cold, then drops to around 5 or 6 running down the road when warmed up. Only knocks in the higher rpms. Thanks guys!
-Matt
| | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Only knocks in the higher rpms It sounds like you need to adjust the rod bearing clerarance by removing a few shims. Either use a piece of Plastigage to get a clearance of .0015" to .002" or put a .0015" piece of shim stock about 1/4" wide between the rod cap and the crankshaft and adjust the shim thickness until a slight drag is felt as you try to turn the crankshaft. Obviously, remove the checking shim before moving on to the next rod! I've even done a little filing on the rod cap to get the right clearance, if all the shims have been removed already. Jerry
