Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 49 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#796316 11/09/2011 3:09 AM
Need some advice here! On my '48 3/4 ton, when going down the road @ around 55, she starts to vibrate & goes away around 65. I pulled the drive shaft & had it checked & had a 4 wheel shop balance the tires (new tires) & check the rims for balance. The king pins are new, I've added an open drive shaft & T5 trans (that I had rebuilt). The vibration is not felt through the steering wheel. I have the shims under the springs & the leafs I rebuilt . Any ideas would be appreciated.
'53 GMC "Ranger"
Maybe have a buddy drive down the freeway with you and watch or record your truck.
Dave
So that used to be a two piece draive shaft, correct? What kind of drive shaft do you have now?
1951 1 Ton Completed
I can think of a couple of things right of the top of my head to check first, lug nut torque and tire pressure. Without knowing what size/type tire you're running, I really can't give you much more of a suggestion on pressure than to start with the oe spec of 45 front/55 rear. Same goes for lug torque, manual calls for 90 ft/lbs.
Bill Burmeister
Truckernix I think you might be onto something here....
I see labluver refers to the driveshaft in singular form.
Apparently drive shafts that are built too long can generate an oscillation and deflect as they spin.
labluver,is the vibration related to engine or wheel speed?
More pix on Flickr.
have the drive shaft balanced.check u-joints,put the truck on jack stands,go through the gears
dan-pa
Check the tires for balance again..............
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
We need more information, what type of drive shaft? how long is it? what gear are you driving in and what rpm does it happen?
Could it be engine vibration from low rpm in overdrive?
Joe
If you hadn't said the kingpins were new, that was going to be my guess. The '46 1 ton pickup my Dad had when I was a kid had bad kingpins. It would vibrate something fierce around 40 mph but then smooth right out again at about 45 or 50. We used to joke that that was when the guardian angel jumped out!!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
A maximum measurement for a gas vehicle driveshaft or anything turning a high RPM is 54" weld to weld depending on diameter. That would be for a 3" x .090 tube. I've had to cut some down to that length or build a new one in larger diameter if it would fit in the vehicle. Absolute maximum is 60". However your vibration problem could be coming from some other source and sometimes can be really difficult to find. I'd also check the engine and transmission mounts as well as all angularity of the engine, trans and driveline. A common vibration issue is an out of phase rebuild on a driveshaft. If it is even a little bit visable then it it wrong. You've checked the obvious so start checking these suggestions.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
You might try this to help isolate the problem. Get up to speed where it is vibrating then put it in neutral and let it idle. If it goes away then rev it back up to what you were doing and see if it comes back.
40 Chevy 1/2 ton
How about getting up to speed while on jack stands. That may tell you something too.
I had a vibration I thought was in my drive line. Before I could really do much about that my water pump went out. I changed it and no more vibration. But I would have sworn on a stack of Bibles that it was something with the drive line.
I have seen a service bulletin for WW2 Canadian Chevs that described vibrations being caused by having the u-bolts that held the u-joints to the drive flange overtightened causing binding.
This bulletin applied only to open drive shaft types with the u-joints attached by u-bolts (as opposed to straps).
The remedy was to ensure no binding of the u-bolts in the drive flange, torque the nuts to 23-25 ft-lb and stake the u-bolt threads below the nuts in case they started to loosen.
