0 members (), 136 guests, and 2 robots.
Topics128,035
Posts1,055,560
#796435 11/09/2011 2:48 PM
I want to do a compression test on the 235 splash oiler that is in my truck but with the plug holes being so small my tester will not fit. What are you guys using to adapt a comp. tester to these older motors ?
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
Most tool suppliers have an adapter. I know that KD and Snap On both have them.
And some compression testers have a rubber tip but you need to hold it in place.
1946 1/2-Ton Chevy
An adapter can be made from a discarded spark plug shell with a little creative drill & tap work. File or grind the crimp away that holds the porcelain center in place, remove it, and tap the shell for the 14MM thread that the later-model engines use. Then thread the adapter onto your compression tester.
Advance auto carries a tester for the 10mm
