0 members (), 35 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#796113 11/08/2011 6:52 AM
Is there a way to drain the antifreeze out of the block of a 216 or will it come out on its own when the radiator drain plug is removed? (had to remove to replace) I just want to make sure my block doesn't crack.
#796124 11/08/2011 11:48 AM
If you have a good mixture of antifreeze in there, the block will not crack.
1951 1 Ton Completed
I miscalculated the mixture I'm not sure what the percent is in there. I don't see the plug and I can't see the pic in the link
#796387 11/09/2011 7:37 AM
You can buy an antifreeze tester at the FLAPS for little money. A good thing to have in the tool box.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Mr. Lang #796395 11/09/2011 8:26 AM
I just looked at a picture of my 216 and the drain on the block is below the intake/exhaust manifold near the back of the engine right next to the bellhousing. I can send you the picture if you like, I had to zoom in on it to see the drain. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
homer52 #796407 11/09/2011 11:52 AM
Petcock on the Lower Right side of the picture, just above the mast jacket and just below the oil pressure line and horizontal accelerator rod. Lowest point on the block, open that and it will drain about all of the coolant from the engine. http://www.pbase.com/dennygraham/image/136174281/original
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
thank you, I'll head out and take another look.
akguy34 #797845 11/14/2011 4:45 PM
How much coolant does the 216 take? I was told 1.8gal then cut 50/50 w/ water which comes to about 4gal. After draining, I can only get about 1.8 gal in. Runs perfect, does not over heat at all.
Don't be too surprised if nothing comes out of the drain hole Denny has indicated. If it does you are in good shape but that seems to be an area of the block that frequently gets blocked with a very herd deposit. You will be able to tell as soon as you open the drain. You may have to remove the whole drain plug, not just turn the threaded part.
Chuck
Oh, and then you may need to poke around in the drain plug hole with some sort of wire to get the flow going. That crud can be pretty hard to break through.
It may not be the easy way, but it is the Cowboy Way - Ranger Doug
Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri
1953 Chevy 3100
1960 Volvo PV 544
1941 Chevrolet Special Deluxe
