1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#7962 09/25/2004 9:06 PM
* Offline
Does anyone know where I can get the shaft for the heat control valve. Counterbalance on one side Heat riser spring one the other.
#7963 09/27/2004 3:43 AM
Place an ad in the swap meet. You will either have to settle for a good used one, or make one yourself.
Fred
52 3600
69 C-10
#7964 09/27/2004 4:44 AM
Brian,
I have seen posts on here before....folks in the warm climates have gone without the heat riser...TX is a lot warmer than MN....you might be able to get away without one...unless you are doing the better than new resto.
