| | | Forums66 Topics128,059 Posts1,055,825 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 34 | Does anyone know where I can get the shaft for the heat control valve. Counterbalance on one side Heat riser spring one the other. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Place an ad in the swap meet. You will either have to settle for a good used one, or make one yourself.
Fred 52 3600 69 C-10
| | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Brian,
I have seen posts on here before....folks in the warm climates have gone without the heat riser...TX is a lot warmer than MN....you might be able to get away without one...unless you are doing the better than new resto. | | |
