3 members (Bill Hanlon, Hanks custodian, Nick in Manitou), 64 guests, and 3 robots.
Topics128,080
Posts1,055,953
Members48,430
#795858 11/07/2011 2:16 PM
Napa lists an oversized King pin set for my 48 ton truck (.020 oversized) Has anyone used this before with success? Because even though I have new kingpins the I-beam has some slop in it and I would like to get it out. I know I can take the whole thing out and have inserts put in or find one that isn't worn out but I would like to avoid that.
1 Offline
Ive seen where plenty of people have used them.. You have to have a set of reamers to do the job. Check around your area to see of you can find a automotive or machine shop that will ream the axle..
Daniel
1953 Chevrolet 3800 Stepside
Thanks,I guess the next step is to take the pins back out and check the hole size to be sure that .020 is enough to get the slop out.
This is hard to believe, but the NAPA dealers in my area did not have a reamer for a steel axle (they had reamers for bushings). The heavy truck shops in this area (Albany, NY) wanted $400+ to ream an axle (a 1/2 hour to 1 hour, $75-$150 job). I bought a good quality adjustable reamer for under $35, delivered. The king pins are now nice and tight (in the axle and in the bushings/knuckles).
You will need to have the axle reamed and the bushings reamed (on a 1-ton truck).
I didn't know .020 were available. I think GM offered .010 as a standard part.
1951 1 Ton Completed
Rockauto.com
1948 Chevrolet Truck:
RAYBESTOS Part # 5301013020 More Information About this Part Professional Grade
Contains Ball Bearing And Metal Bushing; .020" Oversize; 3600 Model
Contains Ball Bearing And Metal Bushing; .020" Oversize; Except Double Duty; 3800 Model
NAPA
1948 Chevrolet Truck 3800 1 Ton Truck
NCP 2621161020
King Pin Set
020" Oversize
Except Double Duty
Contains Ball Bearing & Metal Bushing
Moderated by  Dusty53
