7 members (Dennys28, baldeagle, 1955 1 Series, Gdads51, Barnfind49, Wheelie, 55shaker),
109
Mod | | | Forums66 Topics128,268 Posts1,058,384 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 85 | Napa lists an oversized King pin set for my 48 ton truck (.020 oversized) Has anyone used this before with success? Because even though I have new kingpins the I-beam has some slop in it and I would like to get it out. I know I can take the whole thing out and have inserts put in or find one that isn't worn out but I would like to avoid that. | | | | | Joined: Sep 2010 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 59 | Ive seen where plenty of people have used them.. You have to have a set of reamers to do the job. Check around your area to see of you can find a automotive or machine shop that will ream the axle..
Daniel
1953 Chevrolet 3800 Stepside
| | | | | Joined: Jan 2008 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 85 | Thanks,I guess the next step is to take the pins back out and check the hole size to be sure that .020 is enough to get the slop out. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | This is hard to believe, but the NAPA dealers in my area did not have a reamer for a steel axle (they had reamers for bushings). The heavy truck shops in this area (Albany, NY) wanted $400+ to ream an axle (a 1/2 hour to 1 hour, $75-$150 job). I bought a good quality adjustable reamer for under $35, delivered. The king pins are now nice and tight (in the axle and in the bushings/knuckles).
You will need to have the axle reamed and the bushings reamed (on a 1-ton truck).
| | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | I didn't know .020 were available. I think GM offered .010 as a standard part. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Rockauto.com 1948 Chevrolet Truck: RAYBESTOS Part # 5301013020 More Information About this Part Professional Grade Contains Ball Bearing And Metal Bushing; .020" Oversize; 3600 Model Contains Ball Bearing And Metal Bushing; .020" Oversize; Except Double Duty; 3800 Model
NAPA 1948 Chevrolet Truck 3800 1 Ton Truck NCP 2621161020 King Pin Set 020" Oversize Except Double Duty Contains Ball Bearing & Metal Bushing
