1 members (baldeagle),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | thinking about putting split headers on my 235, but heard that some interfere with the stock steering box. any input would help as to type or manufacture. 53 3100 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Tell us about the headers you are considering. Then, people can tell you if they have seen that set-up work.
I do not recall seeing people posting bad experiences with split headers from parts vendors.
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | My personal opinion would be the clifford intake and headers, but since I have so much time and money into the set up I have now I can't go there, at least with this engine. | | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | i have a fenton 2x1 with fenton headers. no issues with clearance. are you saying since you have so much money into the engine now, that you cant afford headers/aftermarket intake? speedway makes some cheapo steel headers for like 130 bucks, but if you hold out and look, you can find cast iron ones for around 100 bucks used. that's what i picked mine up for. good luck -DVZ | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you are also asking about intakes manifolds, there are multi-carb intake manifolds that interfere with the Advance-Design steering column (and 3-speed column-shift linkages).
