1 members (Danielbolt), 164 guests, and 3 robots.
Topics128,149
Posts1,056,818
Members48,456
#795827 11/07/2011 5:58 AM
I have a lead on a 270 now I have located a 1958- 3 speed Overdrive transmission Casting#3743388 - 4 bolt not 7 frown
Will the tranny replace my stock tranny with 228?
Be the person you would want as a friend because at the end of the game the King and Pawn go in the same box.
A 1949 transmission will be closed torque tube type. A 1958 transmission will be open driveshaft type. If your 1949 is a 1/2 ton with closed driveline, you will need to replace the rear axle. If your truck is a 3/4 ton you will need a new driveshaft made.
Thank you bigbadswingdaddy!!
Somehow my luck is running hot these past 2 wks. Got a lead on another GMC so gonna look at it this week. Might keep this 49 bone stock and mod the other one. He is only asking $250 for entire truck.
