| | | Forums66 Topics128,115 Posts1,056,624 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 42 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 42 | I have a lead on a 270 now I have located a 1958- 3 speed Overdrive transmission Casting#3743388 - 4 bolt not 7  Will the tranny replace my stock tranny with 228?
Be the person you would want as a friend because at the end of the game the King and Pawn go in the same box.
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | A 1949 transmission will be closed torque tube type. A 1958 transmission will be open driveshaft type. If your 1949 is a 1/2 ton with closed driveline, you will need to replace the rear axle. If your truck is a 3/4 ton you will need a new driveshaft made.
| | | | | Joined: Oct 2011 Posts: 42 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 42 | Thank you bigbadswingdaddy!!
Somehow my luck is running hot these past 2 wks. Got a lead on another GMC so gonna look at it this week. Might keep this 49 bone stock and mod the other one. He is only asking $250 for entire truck.
