4 members (Southerntruck, Phak1, DaveV, 2-Ton), 90 guests, and 2 robots.
Topics128,035
Posts1,055,566
#795743 11/06/2011 11:59 PM
i'm in the process of getting my recently rebuilt 261 running and have primmed the pump, (good reading on the gauge) now when i reinstall distributer and set timing and have it running i get NO reading!! I only let it run a short time as i'm afraid as to why no pressure!! It is full of a good break-in oil and new oil line to a functioning gauge. Any ideas boys? Much appreciated!!! frown
boomers59 #795748 11/07/2011 12:08 AM
sounds like you may not have the distributor seated in the oil pump drive. Try taking the distributor loose, with the cap off, and turn the shaft until it drops all the way in.
Bill Burmeister
LONGBOX55 #795753 11/07/2011 12:38 AM
You can not turn the distributor shaft as it has the gear on it. You could loosen the clamp and bump the engine over while pushing down on the distributor to seat it though.
My Blog
Pre '68 Dave #795755 11/07/2011 12:46 AM
That's what I actually meant to say. I think my brain shifted into neutral there for a bit. dang
Bill Burmeister
LONGBOX55 #795759 11/07/2011 1:08 AM
When everything is correct, you should be able to remove the plugs and generate oil pressure on the gauge by turning it over with the starter. There is no need to actually start it up until you get it resolved.
1951 1 Ton Completed
truckernix #795799 11/07/2011 3:32 AM
got it!! Had a buddy of mine tap engine over as i gingerly pushed distributor down, it had about 1/2 of an inch to go and now we got good pressure!! smile Thanks a million!! I had installed a aluminum side plate and the distributer now almost touches it...the origional plate allowed more clearance, neverless i got it squared away. Thanks Dave...we did exactly what you recommended. thumbs_up
