0 members (),
128
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 66 | i'm in the process of getting my recently rebuilt 261 running and have primmed the pump, (good reading on the gauge) now when i reinstall distributer and set timing and have it running i get NO reading!! I only let it run a short time as i'm afraid as to why no pressure!! It is full of a good break-in oil and new oil line to a functioning gauge. Any ideas boys? Much appreciated!!!
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | sounds like you may not have the distributor seated in the oil pump drive. Try taking the distributor loose, with the cap off, and turn the shaft until it drops all the way in.
Bill Burmeister | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You can not turn the distributor shaft as it has the gear on it. You could loosen the clamp and bump the engine over while pushing down on the distributor to seat it though.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That's what I actually meant to say. I think my brain shifted into neutral there for a bit.
Bill Burmeister | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | When everything is correct, you should be able to remove the plugs and generate oil pressure on the gauge by turning it over with the starter. There is no need to actually start it up until you get it resolved. | | | | | Joined: May 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 66 | got it!! Had a buddy of mine tap engine over as i gingerly pushed distributor down, it had about 1/2 of an inch to go and now we got good pressure!!  Thanks a million!! I had installed a aluminum side plate and the distributer now almost touches it...the origional plate allowed more clearance, neverless i got it squared away. Thanks Dave...we did exactly what you recommended.
