2 members (2 invisible),
87
Mod | | | Forums66 Topics128,115 Posts1,056,633 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Members, put my parking brake back together and now it won't stay on...I push the foot pedal and the bar won't bite on it to catch...I think I'm missing parts...It's been months since I took it off. Does anyone have a pic or exploded view of parts? I have the bar,floor spring,square rubber spacer,warped washer and cotter pin.... Thanks | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Jimmi, here's the outside shot,and here's a pic of the inside . Here's some more info too. I hope they help.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Jock, My inside looks like yours...but I don't have anything like whats on the outside.....I just have the hole thru the floorboard,rubber washer and wierd washer...do you know id the washer goes on the inside of the rubber bumper next to the floor board or on the outside next to the cotter pin.? Thanks | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | The large washer goes to the outside,you'll see it on both DADS and my pics. If you put it to the other side of the felt pad it would defeat the function of it. It stops the arm rattling and provides a sound/dirt seal. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Thats what I figured. I took it apart, filed the hole in the keeper, spread the spring, eplaced the leather skinny pad.Still no luck in it biting snd keeping the brake on...I'm stumped, very little parts to screw up...I might try to get another cinch bar and see if thats the problem... Where can I get one of those? Thanks | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Jimmi I'm not sure if anyone is reproducing them. I'd imagine most second hand ones will be pretty worn too,bearing in mind the youngest ones are the best part of 60 years old. I kind of sidetracked onto other things on the truck,but i'll still have to get mine working a bit better,although it did improve slightly when I filed/sharpened the biting edge of the bar.
Maybe you'll get lucky and find one from a truck who's owner parked it in gear rather than using the brake pedal......
It might help to re-post this in general truck talk as it will reach more guys,not everyone checks in here. It's not really a Hi-Po question,more of a general truck querie.
I'm sure we're not the only ones...... 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Jimmi What you seem to need is this: Assembly Manual
~Jim
| | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Big Chevy, I have one of those....doesn't go into great detail..but what I could see ...I have everything...Just won't bite down on the curved rod. Stumped. Thanks | | | | | Joined: Jul 2010 Posts: 89 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 89 | what about sanding the rod so the scratches from sanding go around the rod instead of sanding so scratches run the length of the rod. Sould create small grooves for the catch to bite against and keep from slipping. ?????????
it ain't YOURS 'till it ain't stock!
1951 chevy 3100
| | | | | Joined: Aug 2008 Posts: 28 New Guy | | New Guy Joined: Aug 2008 Posts: 28 | Shop Shark another quality pics view for me to use for the parking brake - Thanks
Your not trying hard enough if you don�t screw up every once in a while.
52 1/2Ton 235 | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Tell exactly what you need, i took mine off 20 years ago and it is in my shop.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
