8 members (Gdads51, frogfarmer, Bill Hanlon, LAROKE, gswbbc, Forty9, 48jim1ton, Hotrod Lincoln),
107
0
Mod | | | Forums66 Topics128,043 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 51 | hi guys i just bought a 1952 3100 with a 235 and i plan to run this as is.. but i would be interested in getting a little moore power out of i.. its already got a split exhaust manifold on there. is there a intake manifold and carb setup i should look for?
any thoughts gentelmen? | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | You might check which head it has on it. There was a higher compression head made for the 235 which you will like. The casting number was 3836848, I believe.
It was used as the replacement head for the 6 cylinder Corvette engine among other stock 235 uses. It was also the head of choice for folks building a 261 racing motor.
Kurt | | | | | Joined: Oct 2011 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 51 | hi ok thanks for the tip i will look into it. will be couple of weeks until i get the car so just doing some resarch in advance! | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Don't fret if you don't have that head. By far ther more common approach to hopping up a 235 was to mill the head 040.-.050. Doesn't make all that much difference anyway. These were low comprsssion engines in the 6.5-7.0:1 range. | | | | | Joined: Oct 2011 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 51 | ok noted ,what do you guys think about intakes? is a dual or even triple just for looks but moore hasle or is ther any gain in this? | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | A properly selected multi carb setup will offer modest improvment in power and economy. Most setups fall short of ideal.
Others might disagree, but I believe it is totally worth the hassel to be able to say you have trips. The biggest hassel is opening your hood everytime somebody wants to see them. | | | | | Joined: Oct 2011 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 51 | lol that kind of hassel i can live with!!! so any spesifik setups you want to share intakes carbs? im a noob you know | | |
