0 members (), 74 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#795584 11/06/2011 11:07 AM
hi guys i just bought a 1952 3100 with a 235 and i plan to run this as is.. but i would be interested in getting
a little moore power out of i.. its already got a split exhaust manifold on there. is there a intake manifold and carb setup i should look for?
any thoughts gentelmen?
chally #795615 11/06/2011 3:52 PM
You might check which head it has on it. There was a higher compression head made for the 235 which you will like. The casting number was 3836848, I believe.
It was used as the replacement head for the 6 cylinder Corvette engine among other stock 235 uses. It was also the head of choice for folks building a 261 racing motor.
Kurt
hi ok thanks for the tip i will look into it. will be couple of weeks until i get the car so just doing some resarch in advance!
chally #795627 11/06/2011 4:34 PM
Don't fret if you don't have that head. By far ther more common approach to hopping up a 235 was to mill the head 040.-.050. Doesn't make all that much difference anyway. These were low comprsssion engines in the 6.5-7.0:1 range.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #795640 11/06/2011 5:19 PM
ok noted ,what do you guys think about intakes? is a dual or even triple just for looks but moore hasle or is ther any gain
in this?
chally #795646 11/06/2011 5:34 PM
A properly selected multi carb setup will offer modest improvment in power and economy. Most setups fall short of ideal.
Others might disagree, but I believe it is totally worth the hassel to be able to say you have trips. The biggest hassel is opening your hood everytime somebody wants to see them.
lol that kind of hassel i can live with!!! so any spesifik
setups you want to share intakes carbs? im a noob you know
