2 members (BC59, Danielbolt),
210
Mod | | | Forums66 Topics128,149 Posts1,056,817 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 245 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 245 | I have a pair of rear AD bumper braces I would like to list on the Stovebolt.I know there is a difference between the 1/2 and 3/4 ton. So how can I tell which is which?
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Are you sure there is a difference? If so, it is probable that you couldn't tell them apart unless you had both side by side. For the most part 1/2 and 3/4 ton trucks had the same parts. I have a set out in the garage and I can't find any numbers on mine. They might or might not be originals, I picked them up at a yard sale of all places. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | The 3/4 ton rear brackets are 2" in height and the 1/2 tons are about a quarter inch or so shorter in height. They are different shapes because of the difference in frame width between the two models. 3/4 ton frame is narrower. | | | | | Joined: Apr 2010 Posts: 245 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 245 | Thank you Ghostrider. These measure 1 3/4" across the flat side of the bars so must be 1/2 ton as would be most common. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thank you.
I have a set of rear bumper braces and they do not fit on my 1/2 ton. I was told there is a difference between the 1/2 ton and 3/4-1 ton rear bumper braces. When I brought this up others say bologne.
Thank you
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Dennis, I'd say (and the Master Parts Books says) those other people are full of baloney: for all A-D years, the bumper brackets are differ for 1/2 ton and 3/4 ton and 1 ton trucks (7.836, below). http://chevy.oldcarmanualproject.com/1929_54chevyparts/07/449.HTM | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | PICTURES Hard to see the differences, but they do not interchange according to Jim carter. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 |
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Maybe they're panel or burb braces. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I have a question since I can't make heads or tails out of the above page. Since the rears are different from 1/2ton to 3/4-1ton does the same go for the front bumper brackets also????joe According to Jim Carter, they are the same: Bumper Braces Front 1947-Early 1955 1/2, 3/4, and 1 Ton | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Unless I am reading the Master Parts book incorrectly (quite possible), it looks like the 47-53 1/2 ton and 3/4 bumper brackets are the same on the front and the 1-ton is different (7.836). Also, the 1954 front brackets look to be different from earlier front bracket??
