2 members (Erniegp, J Lucas),
89
Mod | | | Forums66 Topics128,054 Posts1,055,781 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 15 New Guy | | New Guy Joined: May 2011 Posts: 15 | On a 46 Chevy PU, how does the steering column cover remove from the steering shaft? I have the column and shaft connected to the steering box. I want to remove the outer steering column cover to paint it and grease the inner bearings. Is there a snap ring holding it in, and if so how do you get to it to slide the cover off?
1950 Chevy 3100 5-Window 1946 Chevy Panel 3/4 Ton
| | | | | Joined: Feb 2000 Posts: 5,203 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,203 | The cover has a clamp down at the steering gear box. Loosen it and start twisting and pulling after removing the steering wheel. There is no snap ring or retainer, the steering wheel does that job.
Joe | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | By "steering column cover" do you mean the tube? If so it is pressed into the steering box and not removable without causing damage.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | My 4t6 had the clamp on the bottom like Joe said. I replaced the mast bearing and dropped the horn wire to the hole on the bottom after painting mine. I don't know if if there's enough clearance to pull up thru cab as I had no rear window or no cab on. Been to long ago to remember. Have fun and good luck Dan | | |
