6 members (52Carl, Steelonsteel, Wally / Montana, Gray_Ghost, fonz8261, Stovebolt48), 87 guests, and 0 robots.
Topics128,052
Posts1,055,770
#794234 11/01/2011 3:20 PM
On a 46 Chevy PU, how does the steering column cover remove from the steering shaft? I have the column and shaft connected to the steering box. I want to remove the outer steering column cover to paint it and grease the inner bearings. Is there a snap ring holding it in, and if so how do you get to it to slide the cover off?
1950 Chevy 3100 5-Window
1946 Chevy Panel 3/4 Ton
The cover has a clamp down at the steering gear box. Loosen it and start twisting and pulling after removing the steering wheel. There is no snap ring or retainer, the steering wheel does that job.
Joe
By "steering column cover" do you mean the tube? If so it is pressed into the steering box and not removable without causing damage.
You Tube
My 4t6 had the clamp on the bottom like Joe said. I replaced the mast bearing and dropped the horn wire to the hole on the bottom after painting mine. I don't know if if there's enough clearance to pull up thru cab as I had no rear window or no cab on. Been to long ago to remember. Have fun and good luck
Dan
